Knowledge Base Article
Fatal: (vsim-3421) Value -1 is out of range 0 to 2147483647
Description
You may see this error in the Quartus® II software version 9.1 SP1 and earlier, during simulation of Arria II GX designs containing ALTLDVS IP. The error may occur when you specify a SERDES implemention in LEs and a de-serialization factor of 4 in the IP MegaWizard® Plug-In.
A patch is available to fix this problem for the Quartus II software version 9.1 SP1. Download and install the appropriate patch from the following links:
For Windows:
For Linux:
You must regenerate Altera simulation libraries after you install the patch. ModelSim-Altera users must manually compile and map the altera_mf library to replace the precompiled version included with ModelSim-Altera.
This problem is scheduled to be fixed in the next release of the Quartus II software
Updated 4 months ago
Version 4.0
