Knowledge Base Article
Error: libbytestream.so ELF 32 class not present
Description
Due to a problem in the Quartus® II software, this error may occur when sourcing the libbytestream_pli.so library with the ModelSim®-Altera software or other simulation tools. This error occurs because the simulation tools are expecting a 64-bit version of the library, but only the 32-bit version is found.
Resolution
To work around this issue, delete the following code from the msim_setup.tcl file for ModelSim-Altera (or other corresponding setup script for the simulation tool you are using).
-pli <library directory>/libbytestream_pli.so
This problem is scheduled to be fixed in a future version of the Quartus II software.
Updated 11 months ago
Version 3.0
