Knowledge Base Article
Error: Current module quartus_map ended unexpectedly
Description
You may see this error in the Quartus® II software version 10.1 and 10.1 SP1, if the file /etc/issue has been edited on Linux operating systems.
To work around this problem, restore the original contents of /etc/issue supplied with your operating system.
A patch is available to fix this problem for the Quartus II software version 10.1. To work around this issue, download and install the patch from the links below:
This problem is fixed beginning with the Quartus II software version 11.0.
Updated 4 months ago
Version 4.0
