Knowledge Base Article
Error (175020): Illegal constraint of pin to the region <region> to <region> : no valid locations in region
Description
You may get this error in the Quartus® II software when you are using DQ pins in your design and you have the migration feature enabled. The DQ groups may have conflicting pin locations between migration devices resulting in a lack of usable DQ pins in the respective DQ group. This means that pins in the respective DQ group can only be used as general purpose I/O (GPIO).
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
