Knowledge Base Article
Error (169187): Following feature(s) of I/O pin has invalid setting(s) in the configuration scheme ACTIVE_SERIAL when the pin is placed at pin location Info (169189): I/O feature 'Current Strength' has an invalid setting. The setting should be Default.
Description
If you are using Active Serial or Active Parallel configuration mode in Cyclone® III, Cyclone IV E, or Cyclone IV GX devices and have assigned a non-default current strength setting to the configuration pins, the Intel® Quartus® Prime Software legality check will report the following error:
Error (169187): Following feature(s) of I/O pin <pin_name> has invalid setting(s) in the configuration scheme ACTIVE_SERIAL when the pin is placed at pin location <pin_location>Info (169189): I/O feature 'Current Strength' has an invalid setting. The setting should be Default.
Resolution
The requirement for all Cyclone III, Cyclone IV E, and Cyclone IV GX devices is to set the following default settings on the Active Serial or Active Parallel configuration pins:
a. Weak pull up = on
b. Bushold = off
c. PCI_IO = off
d. Slew rate = 2
e. Open drain = off
f. Vod = -1
g. Pre-emphasis = -1
h. Current strength = default
i. I/O standard = 3.3/3.0/2.5/1.8 (LVTTL/LVCMOS)
Updated 11 months ago
Version 3.0
