Knowledge Base Article
Error (10430): VHDL Primary Unit Declaration error at alt_cusp151_package.vhd
Description
Due to a problem in the Quartus® Prime software version 15.1.2 and earlier, you may see this error when compiling a design with multiple Qsys systems that elaborate alt_cusp151_package.vhd.Resolution
To work around this problem, combine the Qsys systems into a single Qsys system.
If you unable to combine the Qsys systems then follow these steps:
1) Move the affected Qsys files to the top and bottom of the file list
2) When you see the first affected qsys finish elaboration, navigate to the folder /db/ip/<qsys_project>/submodules and delete alt_cusp151_package.vhd before the second Qsys system elaborates
This problem is scheduled to be fixed in a future release of the Quartus Prime software.
Updated 3 months ago
