Knowledge Base Article
Error (10119): Verilog HDL Loop Statement error at <location>: loop with non-constant loop condition must terminate within <number> iterations
Description
This error may appear in the Quartus® II software when synthesis iterates through a loop in Verilog HDL for more than the synthesis loop limit. This limit prevents synthesis from potentially running into an infinite loop. By default, this loop limit is set to 250 iterations.
Resolution
To work around this error, the loop limit can be set using the VERILOG_NON_CONSTANT_LOOP_LIMIT option in the Quartus II Settings File (.qsf). For example:
set_global_assignment -name VERILOG_NON_CONSTANT_LOOP_LIMIT 300Updated 11 months ago
Version 3.0No CommentsBe the first to comment
