Knowledge Base Article
Does the DSPBA support dual write ports?
Description
When DSPBA creates a dual-port memory (e.g using sharedMem block), as you can see from below port map, the port A is used as the write port and port B is the read port, where the read port input (“data_b”) is present but not used, it means that the dual write ports is not supported at the moment.
PORT MAP (
clocken0 => '1',
wren_a => DGains_we_q(0),
aclr0 => DGains_dm_reset0,
clock0 => clk,
address_b => DGains_dm_ab,
-- data_b => (others => '0'),
q_b => DGains_dm_iq,
q_a => DGains_dm_ir,
address_a => DGains_dm_aa,
data_a => DGains_dm_ia
Resolution
The dual write ports are not supported now, however it will enhance in future version.Updated 11 months ago
Version 3.0No CommentsBe the first to comment
