Knowledge Base Article
Do I need to apply any pin assignments to the ASMI pins ASDO, DATA, nCSO or DCLK when using the Altera ASMI Parallel Megafunction?
Description
No, you don’t need to apply any pin assignments to the ASMI pins ASDO, DATA, nCSO or DCLK when using the Altera® ASMI Parallel Megafunction.
The Megafunction is already internally connected to the dedicated asmiblock, which has a direct connection to the physical ASMI pins in the FPGA devices.
Updated 1 month ago
