Knowledge Base Article
DMA_afu simulation example pCLK is set at 400 MHz instead of 250 MHz
Description
The out-of-box simulation runs the pCLK at 400MHz, while in the FPGA Interface Manager Data Sheet, the pCLK is set to 250MHz.
Resolution
As ASE is a functional model, changing the pClk frequency won't make performance estimates any more accurate. If the developer still wants to edit the clock’s value, changes need to be made in ASE's rtl/platform.vh in the clock section.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
