Knowledge Base Article
couldn't load library "/libtcl3.2.a": this library or a dependent library could not be found in library path
Description
This error occurs when you start the Modelsim®-Altera® simulator if you have installed a version of the ModelSim-Altera simulator into the same directory as a previously installed version.
To avoid this problem, install the software versions in different directories. To fix the error, uninstall both versions of the ModelSim-Altera simulator, delete the directory and reinstall the simulator into a new directory.
The full error message is as follows:
couldn't load library "C:/Modeltech_ae/win32/aloem/../tcl/itcl3.2/../libtcl3.2.a": this library or a dependant library could not be found in library path
while executing
"load C:/Modeltech_ae/win32aloem/../tcl/itcl3.2/../libitcl3.2.a Itcl"
("package ifneeded" script)
invoked from within
"package require Itcl"
invoked from within
"ncFyP12"
(file "C:\Modeltech_ae\win32aloem/../tcl/vsim/vsim" line 1)
Updated 11 months ago
Version 3.0
