Knowledge Base Article
Can I use Serial Flash Controller, Generic QUAD SPI Controller, Serial Flash Loader and ASMI Parallel IP in any configuration mode?
Description
If using EPCS, EPCQ or EPCQ-L configuration devices with the Serial Flash Controller and Generic QUAD SPI Controller IP, your Intel® FPGA must be in Active Serial (AS) configuration mode. The Serial Flash Loader and ASMI Parallel IP always use EPCS, EPCQ, and EPCQ-L configuration devices, so they always require the FPGA to be in AS configuration mode.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
