Knowledge Base Article
Can I use an external USB-to-Parallel Port converter with the ByteBlaster II download cable if my computer does not have a parallel port?
Description
No, you may not use an external USB-to-Parallel Port converter to convert the USB port of your working computer to parallel port in order to use the Altera® parallel download cables such as the ByteBlaster™ II download cable.
The parallel port download cable only works with the parallel port set to ECP mode. If the USB-to-Parallel Port converter is used, this Parallel Port is defined as a COM port, which is a serial port and it cannot communicate with the Altera parallel port download cables. For more information on available programming hardware, refer to the Download Cables webpage.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
