Knowledge Base Article
Can I synthesize Altera Megawizard generated IP using third party synthesis tools?
Description
No, Altera® Megawizards IPs are designed only to work with Quartus® II software Analysis and Synthesis. They cannot be synthesized with 3rd party synthesis tools.
Here is an example on how to use Altera IP in Synplify:
Quartus II software help
* Synopsys Synplify Support (PDF)
You should either use the syn_black_box directive or in Verilog you can supply an empty module and Synplify will automatically infer it as a black box. This empty module is the *_bb.v file generated from the Megawizard.
Updated 11 months ago
Version 3.0
