Knowledge Base Article
Assertion failed: !areInvalidOperands(C, S1, S2) && "Invalid operands for select")
Description
Due to a problem in the Intel® OneAPI Base Toolkit (Base Kit) version 2023.2, you might see this error.
Resolution
To workaround this problem, download and install the 2023.2.1 patch from the links below
  1. Determine where the 2023.2 oneAPI base toolkit is installed. The FPGA Add-on will be located inside of the toolkit installation directory in the ‘oclfpga’ folder.
    • For Linux, this will be ‘<install-dir>/intel/oneapi/compiler/2023.2.0/linux/lib/oclfpga’, where <install-dir> is typically either ‘/opt’ or ‘~’.
    • For Windows, this will usually be ‘C:\Program Files (x86)\Intel\oneAPI\compiler\2023.2.0\windows\lib\oclfpga’.
  2. Rename the existing ‘oclfpga’ directory to something else, e.g., ‘oclfpga.bak’ or ‘oclfpga.prev’.
  3. Unpack the given archive, .tar.gz for Linux and .zip for Windows, to extract the ‘oclfpga’ folder and place it in ‘intel/oneapi/compiler/2023.2.0/<platform>/lib’, where <platform> is either ‘windows’ or ‘Linux’ (see above).
  4. (Optional) Remove the backup folder created in Step ‘2’ after testing.
This problem is scheduled to be fixed in a future release of the Intel® OneAPI Base Toolkit (Base Kit).
Updated 8 months ago
Version 4.0
