Knowledge Base Article
Are programming files compatible between commercial and industrial grade devices?
Description
Yes, programming files are compatible between commercial and industrial grade devices. Programming files are speed grade and temperature grade independent.
To ensure that the timing model is correct, you should choose the device in Quartus® II software that matches the temperature rating marked on the device.
Some device features are restricted in the industrial temperature range (refer to the respective device handbook and errata sheet for any functional differences between commercial and industrial devices).
Related Articles
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
