Knowledge Base Article
An error occured during the move data process: -132
Description
You may get the following error when you install the Modelsim®-Altera® simulator version 5.8c over an existing version:
If you want to install the software in a directory that contains another version of the Modelsim simulator, Altera strongly recommends you first uninstall the previous version using the following steps:
  1. Using Add/Remove Programs from the Windows Control Panel, uninstall the Modelsim-Altera software
  2. Restart Windows (required if you have previously installed drivers for the Hardware key)
  3. Install the Modelsim-Altera software
Alternately, you can install the Modelsim-Altera software into a new directory.
Updated 11 months ago
Version 3.0
