Knowledge Base Article
*** Fatal Error: Segment Violation: faulting address=0x8, PC=0x7ffff3c8a910 : 0x7ffff3c8a910: Qt6Widgets!QWizardPage::wizard() const or PTC ERROR: [epe_architecture.cpp:3217] it != m_ip_elements.end()
Description
Due to a problem in the Altera® Power and Thermal Calculator Software (PTC) version 25.1, you may encounter this fatal error when selecting the IP Wizard function. The problem only occurs when a member of the Agilex™ 3 FPGA device family is the currently selected device.
Resolution
Avoid use of the IP Wizard function and add the desired IP resources manually when working with the Agilex™ 3 FPGA device family.
**This problem is scheduled to be fixed in a future version of the Power and Thermal Calculator.
Updated 3 months ago
Version 2.0
