Knowledge Base Article
How do I edit an image?
Once an image is uploaded to the community, it cannot be edited directly. This includes both the image itself and any associated metadata.
  • To change an image, you must edit your post, remove the existing image, and upload the updated image.
  • Any text, description, or context should be updated in the post body itself.
  • Images attached to posts are tied to that post; there is no separate album or metadata editor.
Tip: Always double-check your image before uploading to avoid needing replacements.
Published 9 months ago
Version 1.0
