13 years agoDDR3 discret component skew question
Hi all, I'm designing a new board based on an ARRIA V with 2 DDR3 component. Both of them are x16 DQ. I routed CLK, address and command as T-topology. I want to use the Hard External Memory Int...
13 years agoI didn't explain my problem very well, you misunderstand me :
I'm looking for the max deviation between byte-groups ? I'm, also, looking for the max deviation between byte-groups and clocks ? I find in the Board Skew Parameter Tool : - the max deviation between byte-groups is 1 ns (according to me it's + or - 158 mm). - the max deviation between byte-groups and clock is 0ps?!!? (I think that's mean that byte-groups track have to be shorter than clocks track.) Is that correct ?
