15 years agoCyclone IV receiving 5V PECL
I want to drive differential input pairs with 5V PECL. Can I use the diff input with a 3.3V VCCIO or is this prevented? If I can, what is the max common mode and max input voltage? I'm considering DC...
15 years agoThe differential inputs aren't specified for 3.3V VCCIO, thus I won't use it.
The LVDS common mode input range has different specifications depending on the speed, e.g. with Cyclone IV maximum VCM is 1.55 V for hghest data rate. Considering the high differential level of PECL, an impedance matched resistive divider will do, like 120/80 ohm.
