Intel has announced new technology that combines FPGA die with high-speed analog chiplets that incorporate both ADCs and DACs operating as fast as 64 Gsamples/sec. With analog sampling rates that fast, this technology represents a revolutionary step towards providing direct RF capability for radar, test & measurement, and wireless communications systems. This heterogeneous system-in-package technology leverages Intel’s Embedded Multi-die Interconnect Bridge (EMIB) and the open standard Advanced Interface Bus (AIB) to seamlessly integrate the ADC/DAC chiplet with the FPGA die.
Beamforming systems used in radar and other mission critical applications are currently designed with 32 or more antenna elements sharing a single analog converter. This new architecture significantly increases algorithm complexity and requires substantially more digital signal processing (DSP), memory, and logic FPGA resources. As a result, these systems are now transitioning to wider bandwidth, all-digital designs, where each antenna element connects directly to an ADC and DAC. This all-digital architecture reduces the amount of data transmitted through a system and speeds the transmission of actionable information to enable more rapid decision making by placing required computing resources closer to the sensor.
Intel’s state-of-the-art heterogeneous packaging technology can connect chiplets from different processing nodes, including the ADC/DAC chiplet, to the FPGA fabric. This packaging technology connects chiplets using thousands of wires, each operating at 1 Tbps, using EMIB interconnect technology and the AIB physical layer protocol. Combining the high-speed converters with the FPGA in one packaged device eliminates the need for SERDES or JESD204 package-to-package interconnects and significantly reduces power consumption.
The first Intel offering to employ this technology will feature an analog data converter with input sample rates up to 64 Gsamples/sec. This offering will combine high-performance ADCs and DACs with a high-density, high-performance FPGA fabric and other dedicated transceiver chiplets in one package.
For more information, click here.
Notices & Disclaimers
Intel technologies may require enabled hardware, software or service activation.
No product or component can be absolutely secure.
Your costs and results may vary.
© Intel Corporation. Intel, the Intel logo, and other Intel marks are trademarks of Intel Corporation or its subsidiaries. Other names and brands may be claimed as the property of others.
Published 5 years ago
Version 1.0sleibson
Joined March 17, 2021
Blog
Connect with experts on FPGAs and Programmable Solutions
