Blog Post
Blog
3 MIN READ
How Agilex® 5 and Quartus® Software Deliver Performance and Efficiency in Mid-Range FPGA Designs
andreanova's avatar
andreanova
3 months ago
How a published OpenCores study connects workload behavior, fabric architecture, and software optimization.
Mid-range FPGA designers rarely optimize for only one thing. A design has to fit. It has to close timing. It has to stay within the power budget. As more functions move into the same device, those requirements become harder to satisfy at the same time.
That is why the combination of fabric architecture and software matters.
A new Altera white paper, ”Altera Delivers Superior Performance, Power, and Logic Packing with Quartus® and Agilex® 5 FPGAs Versus AMD Kintex™ UltraScale+”, examines this challenge using twelve publicly available OpenCores benchmark designs. The study compares Agilex® 5 E-Series devices with AMD Kintex™ UltraScale+ devices using each vendor’s recommended software flow and a stamping methodology that increases utilization by replicating each design across the FPGA.
FPGA performance is application-dependent, and the paper’s value is in showing how different workload types stress different parts of the FPGA architecture and implementation software, highlighting where Agilex 5 E-Series demonstrates meaningful advantages.
Why Agilex 5 E-Series is well suited for these workloads
Agilex 5 E-Series is designed for mid-range applications that need a balance of performance, power efficiency, and integration density. Its fabric combines HyperFlex™ architecture, adaptive logic modules, embedded M20K memory, and Quartus® Prime optimization technology. Just as important, its regular fabric structure and scalable interconnect help routing remain more predictable as utilization rises. That matters because timing closure is often limited by placement and routing pressure, not only by raw logic count.
Because Agilex 5D shares the same underlying Agilex 5 fabric architecture, these fabric-level advantages extend to the D-Series as well, with higher device density, greater on-chip resource capacity, and approximately 20% higher fabric performance.
Where the advantages show up
For designs where routing and timing closure dominate, such as deeply pipelined processor and error-correction workloads, Agilex 5 E-Series benefits from HyperFlex retiming and register duplication. These capabilities help break up long interconnect paths, reduce critical path depth, and sustain fMAX as replicated design instances push utilization higher.
For arithmetic-heavy workloads, such as trigonometric, DSP, and iterative compute kernels, Agilex 5 adaptive logic modules help pack arithmetic more locally and efficiently. Better local packing can reduce routing overhead, which becomes increasingly important as dense compute designs scale across the device.
For memory-sensitive and resource-constrained workloads, including video, security, and embedded compute designs, embedded memory and logic packing become key limiters. Agilex 5 E-SeriesM20K resources and efficient ALM utilization help preserve usable logic capacity and timing margin when competing implementations may need more LUT-based memory or additional routing resources.
For designs where implementation efficiency depends heavily on the tool flow, Quartus Prime advanced synthesis and physical synthesis add another part of the formula. The software can co-optimize logic, placement, and routing, helping improve utilization and power efficiency without requiring RTL changes.
The proof, and what it means
The published white paper provides the detailed benchmark data, but several results stand out because they connect directly to real design challenges:
  • 22% higher geometric mean performance at high-utilization operating points. This matters because FPGA designs often become harder to close as utilization rises. Higher performance under those conditions points to better timing behavior when routing pressure, placement density, and resource contention increase.
  • More stable achievable fMAX as utilization increases. The paper shows less frequency degradation for Agilex 5 E-Series as benchmark instances are stamped across the device. For designers, that means more predictable timing closure as the design approaches fuller device usage.
  • 47% lower total power at iso-frequency and iso-workload conditions. This result isolates power at equivalent workload and clock frequency, showing that Agilex 5 E-Series can do the same work with significantly lower total device power in the evaluated designs.
  • Up to 2.83x greater energy efficiency in individual workloads. This shows that the advantage is not only about reducing watts. It also reflects better work-per-watt behavior, which can help improve thermal margin, power budgets, and system-level efficiency.
  • 17% higher effective device capacity. In this context, effective capacity reflects the amount of design logic that can be implemented while still meeting timing constraints
Read the full white paper
This blog highlights the key findings, but the full whitepaper provides detailed benchmark data, workload-by-workload analysis, methodology transparency, and architectural insights across all twelve OpenCores designs.
Read the whitepaper to understand how Agilex 5 E devices and Quartus Prime software delivered higher performance, lower power, and greater effective design capacity across a diverse set of real FPGA workloads.
Altera Delivers Superior Performance, Power, and Logic Packing with Quartus® and Agilex® 5 FPGAs Versus AMD Kintex™ Ultrascale+
Updated 3 months ago
Version 1.0
