Knowledge Base Article
XAUI PHY megafunction generates warning messages in the MegaWizard Plug-In Manager
Description
When you generate a XAUI PHY megafunction with the XAUI PHY MegaWizard Plug-In Manager, if you select, on the General Options tab, Hard XAUI in the XAUI interface type box, the MegaWizard Plug-In Manager generates messages similar to the following:
Warning: <connection name> must be connected to an Avalon-ST sink Warning: <connection name> must be connected to an Avalon-ST source
If you turn on Include control and status ports on the Advanced Options tab, the MegaWizard Plug-In Manager generates the following additional message:
Warning: <connection name> cannot be both connected and exported
When you generate a XAUI PHY megafunction with the XAUI PHY MegaWizard Plug-In Manager, if you select, on the General Options tab, Soft XAUI in the XAUI interface type box, the MegaWizard Plug-In Manager also generates messages similar to the following:
Warning: alt_pma_0.tx_out_clk: Signal tx_out_clk[4] of type clk must have width [1] Warning: alt_pma_0.rx_recovered_clk: Signal rx_recovered_clk[4] of type clk must have width [1] Warning: sxaui_0.tx_out_clk: Signal tx_out_clk[4] of type clk must have width [1] Warning: sxaui_0.rx_recovered_clk: Signal rx_recovered_clk[4] of type clk must have width [1]
Resolution
These messages do not affect generation. You may safely ignore these messages.
Updated 1 month ago
Version 2.0
