Knowledge Base Article
Wrong Default Value
Description
If you generate the core targeting a Cyclone IV E device with the high-performance controller architecture, without creating a new project first , the MegaWizard Plug-In Manager selects the default speed grade and clock frequency values that are not supported. If you generate the core,The given combination of PLL input and output cannot be synthesized. error message appears.
This issue affects all designs that use the high-performance controller architecture targeting Cyclone IV E devices .
Your system cannot be generated.
Resolution
Create a new project and select the device first before generating the core. Make sure to specify the speed grade to a value higher that 8, and the clock frequency to a value higher that 200 MHz.
This issue will be fixed in a future version of the DDR and DDR2 SDRAM Controllers with ALTMEMPHY IP.
Updated 26 days ago
Version 2.0
