Knowledge Base Article
Will a programming file be generated if I am using Quartus II design software subscription edition in evaluation mode?
Description
No, if you are using Quartus® II design software subscription edition in the 30-day free evalution mode then no programming file(s) will be generated. You will need a valid license file to enable programming file generation.
Updated 3 months ago
Version 2.0
