Knowledge Base Article
Why there is no video output seen after programming the SDI II IP multi-rate or triple-rate design with the Agilex™ 7 FPGA device using the Quartus® Prime Pro Edition Software Programmer v22.2?
Description
Due to a problem in the Quartus® Prime Pro Edition Software Programmer version 22.2, no SDI II video output is displayed on the receiver side when using the SDI II IP multi-rate or triple-rate designs on Agilex™ 7 FPGA devices. This is due to the rx_ready signal not being asserted after performing dynamic reconfiguration of the F-Tile PHY transceiver. This issue impacts all SDI II IP design examples that support dynamic reconfiguration.
Resolution
A patch is available to fix this problem for the Quartus® Prime Pro Edition Software Programmer version 22.2.
Download and install Patch 0.06 below.
This problem is scheduled to be fixed in a future release of the Quartus® Prime Pro Edition Software.
Related Articles
Updated 8 months ago
Version 3.0No CommentsBe the first to comment
