Knowledge Base Article
Why the designs fail compilation when Enable TX PLL is selected for SDI Dual Link?
Description
The design might fail compilation and receive the following error if turn on the "Enable TX PLL select for 1/1.000 and 1/1.001 data rate reconfiguration" for SDI dual link.
Error (167085): Atom "<name of IP>:inst|sdi_megacore_top:sdi_megacore_top_inst|sdi_txrx_port:sdi_txrx_port_gen[0].u_txrx_port|rc_s4gxb_tx_2pll:gen_tx_alt4gxb_2pll.u_gxb|alt4gxb:alt4gxb_component|alt4gxb_0i67:auto_generated|tx_pll0" of type "GXB PLL" can only be clocked from one of the following core signals
    Info (167001): I/O input buffer atom "tx_serial_refclk~input"
    Info (167001): I/O input buffer atom "tx_serial_refclk1~input"
This issue only happens in Stratix® IV and Arria® II devices if the IO_STANDARD of tx_serial_refclk & tx_serial_refclk1 are not defined properly.
Resolution
Adding these lines into the project qsf file is able to fix the issue.
set_instance_assignment -name IO_STANDARD "1.5-V PCML" -to tx_serial_refclk1
Or
set_instance_assignment -name IO_STANDARD "LVDS" -to tx_serial_refclk1
Updated 11 months ago
Version 3.0
