Knowledge Base Article
Why the Arria II GX SerialLite II megafunction supports up to 3750Mbps only although datasheet specifies that the Arria II GX I3 device's transceivers can support up to 6375Mbps?
Description
The Arria® II GX SerialLite II core uses the transceiver in Single-width mode and the maximum data rate limit for this mode is only 3750 Mbps. Currently, there are no plans to upgrade Arria II GX SerialLite II core to use Double-width mode.Updated 1 month ago
