Knowledge Base Article
Why parameter of component "H-tile of Stratix" was observed via SI simulation tool such as Hyperlynx when I use S10 IBIS-AMI model(L-tile), stratix10_ltile_hssi_ibis_ami_v1p8.zip ?
Description
The device model, stratix10_ltile_hssi_ibis_ami_v1p8.zip is located in the SPICE Models for Intel® FPGAs web page.
Due to an error in the s10gxl_ami_tx_5p1.ibs file, the [component] value is represented as Stratix-10H_Tx.
Resolution
In the s10gxl_ami_tx_5p1.ibs file, manually change the [component] value from Stratix-10H_Tx to Stratix-10L_Tx.
Updated 3 months ago
Version 3.0
