Knowledge Base Article
Why might RapidIO I port_ok status signal not assert after link re-initialization?
Description
port_ok status in bit-0, Port 0 Error and Status CSR (0x158) may stay at LOW after link re-initialization occurs. Link re-initialization  is done either  by the triggering of bit-23 PORT_DIS in Port 0 Control CSR (0x15C), or when link partner is performing reset. This may cause  fatal error during normal operation,
This issue happens due to the following reasons:
  • The RapidIO core may be out of reset prior to transceiver coming out of reset. This causes the RapidIO core to start operation while the transceiver is still in reset.
  • The word re-alignment process is limited to lane 0, and will trigger only once during link re-initialization.
This issue affects the following RapidIO I variants:
  • Arria® V/Cyclone® V with x2 mode.
  • Arria V/Cyclone V at baud rate 5000 Mbaud.
  • Arria V with x4 mode at baud rate 3125 Mbaud.
Resolution
To ensure that the transceiver is out of reset and ready to start any operations before the RapidIO core, qualify the RapidIO core reset with the transceiver ready status signals in module <your_ip>_riophy_reset:
//TX_SIDE
always @(posedge tx_clk or negedge reset_n)
begin
        if (!reset_n) begin
            tx_ready_s0 <= 1'b0;
            tx_ready_s1 <= 1'b0;
        end else begin
            tx_ready_s0 <= tx_ready;
            tx_ready_s1 <= tx_ready_s0;
        end
end
always @ (posedge tx_clk or negedge reset_n) begin
 if(!reset_n)begin
    txreset_n_p2 <= 1'b0;
    txreset_n_p1 <= 1'b0;
    txreset_n <= 1'b0;
  end else begin
    if (!gxbpll_locked_tx_clk_d2 || !tx_ready_s1) begin
      txreset_n <= 1'b0;
    end else begin
      txreset_n_p2 <= 1'b1;
      txreset_n_p1 <= txreset_n_p2;
      txreset_n <= txreset_n_p1;
    end
  end
end
//RX_SIDE
always @(posedge rx_clk or negedge reset_n)
begin
    if (!reset_n) begin
        rx_ready_s0 <= 1'b0;
        rx_ready_s1 <= 1'b0;
    end else begin
        rx_ready_s0 <= rx_ready;
        rx_ready_s1 <= rx_ready_s0;
    end
end
always @ (posedge rx_clk or negedge reset_n) begin
 if(!reset_n)begin
    rxreset_n_p2 <= 1'b0;
    rxreset_n_p1 <= 1'b0;
    rxreset_n <= 1'b0;
  end else begin
    if (!rx_ready_s1) begin
        rxreset_n_p2<=1'b0;
        rxreset_n_p1<=1'b0;
        rxreset_n<=1'b0;
    end else begin
        rxreset_n_p2 <= 1'b1;
        rxreset_n_p1 <= rxreset_n_p2;
        rxreset_n <= rxreset_n_p1;
    end
  end
end
To trigger word re-alignment process manually, perform the following steps through the Avalon-MM phy_mgmt transceiver interface:
(1) Assert phy_mgmt_write=1'b1 to specify the write operation.
(2) Write data phy_mgmt_writedata=32'b0 into address phy_mgmt_address=9'h80 to target for lane 0.
(3) Write data phy_mgmt_writedata=32'b1 into address phy_mgmt_address=9'h85 to assert rx_enapatternalign which will trigger word alignment operation for lane 0.
(4) Write data phy_mgmt_writedata=32'b0 into address phy_mgmt_address=9'h85 to deassert rx_enapatternalign.
Repeat the steps above for all other lanes: lane 1 (0x80=32'b1), lane 2 (0x80=32'b2), and lane 3 (0x80=32'b3).
Updated 1 month ago
Version 2.0
