Knowledge Base Article
Why might my E-Tile Hard IP for Ethernet IP occasionally transmit duplicate or reordered words after power-up when used in Intel® Stratix® 10 or Intel Agilex® 7 FPGAs?
Description
Your E-Tile Hard IP for Ethernet IP may occasionally transmit duplicate or reordered words after power-up when used in Intel® Stratix® 10 or Intel Agilex® 7 devices if the E-Tile Hard IP for Ethernet IP is in an AIB channel phase-locked loop (PLL) clocked, multiple-channel, fractured host-agent configuration and the initialization reset sequence has not been followed.
Resolution
To reliably bring up your AIB channel PLL clocked, multiple-channel, fractured master-slave configured E-Tile Hard IP for Ethernet IP, you must implement the following sequence.
1. Assert i_sl_csr_rst_n[3:0] and i_reconfig_reset.
2. Wait until your channel AIB PLL aib_pll_lock signal asserts.
3. De-assert the i_sl_csr_rst_n[master_channel] and i_reconfig_reset signals.
4. Wait 10 ms.
5. De-assert the i_sl_csr_rst_n[slave_channels] signal.
The requirement to sequence the de-assertion of the host-agent channel i_sl_csr_rst_n[3:0] signals will be added to a future revision of the E-Tile Hard IP for Ethernet and E-Tile CPRI PHY Intel® FPGA IP User Guide.
