Knowledge Base Article
Why might I see incorrect clock frequency in the khz_rx (0x341) and khz_tx (0x342) registers of E-Tile Hard IP for Ethernet Intel® FPGA IP ?
Description
You might see incorrect frequency in the khz_rx (0x341) and khz_tx (0x342) registers of E-Tile Hard IP for Ethernet Intel® FPGA IP if the i_reconfig_clk frequency is not 100 MHz.
Because the frequency value is measured on the assumption that the i_reconfig_clk frequency is 100 MHz.
Resolution
If the i_reconfig_clk frequency is not 100 MHz, the khz_rx (0x341) and khz_tx (0x342) register values are calculated with the equation below, respectively.
  • khz_rx (0x341) : Recovered clock frequency /10* [100 MHz / i_reconfig_clk (MHz) ], in KHz
  • khz_tx (0x342) : TX clock frequency /10* [100 MHz / i_reconfig_clk (MHz) ], in KHz
The description problem is scheduled to be fixed in a future release of the UG-20160.
Updated 2 months ago
Version 2.0
