Knowledge Base Article
Why isn't the Ethernet Subsystem FPGA IP displayed in the IP Catalog when you use the Agilex™ 7 FPGA M-Series devices?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 24.2, you may not see the Ethernet Subsystem FPGA IP in the IP Catalog when you use the Agilex™ 7 FPGA M-Series devices.
When using the Agilex™ 7 FPGA M-Series or I-Series devices, the Ethernet Subsystem FPGA IP can be seen in the IP Catalog.
Resolution
To work around this problem in the Quartus® Prime Pro Edition software version 24.2, you can generate the Ethernet Subsystem FPGA IP using the command-line method below instead of the IP Catalog GUI.
- qsys-edit --new-component-type=<IP Name> --family=<Family Name> --part=<Device> <IP File name>
For instance,
- qsys-edit --new-component-type=hssi_ss --family="Agilex 7" --part=AGIB027R31B1E2V eth_subsystem.ip
This problem is fixed beginning with the Quartus® Prime Pro Edition software version 24.3.1.
Updated 3 months ago
