Knowledge Base Article
Why is timing not closing in my Stratix V Hard IP for PCI Express on Quartus 13.1?
Description
Timing may not closing in the Stratix® V Hard IP for PCI® Express because constraints are missing on internal clocks that are in separate domains.Resolution
The missing constraints can be added to your top level Synopsis Design Constraint (sdc) file as below:
set_false_path -from [get_clocks {reconfig_xcvr_clk}] -to [get_clocks {*|altpcie_hip_256_pipen1b|stratixv_hssi_gen3_pcie_hip|coreclkout}]
set_false_path -from [get_clocks {*|altpcie_hip_256_pipen1b|stratixv_hssi_gen3_pcie_hip|coreclkout}] -to [get_clocks {reconfig_xcvr_clk}]
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
