Knowledge Base Article
Why is there higher than expected FPGA resource utilization when instantiating the RAM: 2-Port Intel® FPGA IP with the Emulated TDP dual clock mode parameter enabled?
Description
When a RAM: 2-Port Intel® FPGA IP with the Emulated TDP dual clock mode parameter enabled is instantiated in the Intel® Quartus® Prime Software, you might see a higher-than-expected FPGA resource utilization when targeting Intel® Stratix® 10 devices. This is caused by the additional FIFOs implemented by the RAM: 2-Port Intel® FPGA IP.
Resolution
To work around this problem, perform the following steps:
  1. Navigate through the hierarchy and find the fifo_wrapper_in instance.
  2. Move on through the hierarchy until you come across the dcfifo_component instance.
  3. Reduce the value of the LPM_NUMWORDS and LPM_WIDTHU parameters. The value assigned for LPM_NUMWORDS must comply with the following equation: 2^LPM_WIDTHU. Make sure the FIFO depth is appropriate to support the data rate of your design.
As an example:
dcfifo_component.lpm_numwords  = 16
dcfifo_component.lpm_widthu  = 4
  1. Repeat steps 1 to 3 for the fifo_wrapper_out instance.
Updated 2 months ago
Version 2.0
