Knowledge Base Article
Why is there critical Design Assistant violation reported at Synthesis stage after Scalable Scatter-Gather DMA IP DMA PCIe Mode Example Design compilation?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 24.3, critical Design Assistant violation may be reported after Scalable Scatter-Gather DMA IP DMA PCIe Mode Example Design compilation because of incorrect IP settings of GTS Reset Sequencer IP in the example design. The Enable PCIE and/or HPS USB3.1 only design parameter is not enabled.
Resolution
To work around this problem in the Quartus® Prime Pro Edition Software version 24.3, follow the steps below.
- Open the GTS Reset Sequencer IP instance in the example design and enable the Enable PCIE and/or HPS USB3.1 only design parameter. Save the change and regenerate HDL of the GTS Reset Sequencer IP.
- Open ssgdma_ed_top.sv, remove lines 603-605 on o_src_rs_grant, i_src_rs_priority, i_src_rs_req signals of GTS Reset Sequencer IP instance. Save the changes.
- Recompile the example design.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
