Knowledge Base Article
Why is there an unconstrained clock reported when using the Dual Configuration Intel® FPGA IP on Intel® MAX® 10?
Description
An unconstrained clock is reported as shown below when using Dual Configuration Intel® FPGA IP on MAX®10:
altera_dual_boot:dual_boot_0|alt_dual_boot_avmm:alt_dual_boot_avmm_comp|alt_dual_boot:alt_dual_boot|ru_clk
Resolution
To work around this problem, generate timing constraints including the command "create_generated_clock" in the SDC file.
Updated 2 months ago
Version 2.0
