Knowledge Base Article
Why is there an error when I run the UniPHY-based IP pin_assignments.tcl after Analysis & Synthesis is completed?
Description
If you attempt to run the UniPHY-based <IP variation name>_pin_assignments.tcl after Analysis & Synthesis, you will get the following error:
Error:"source "<path to file>/*_pin_assignments...."
Resolution
The workaround is to run a full compilation instead of Analysis & Synthesis and wait until the compilation fails during the Fitter. Then run the <IP variation name>_pin_assignments.tcl.Updated 1 month ago
