Knowledge Base Article
Why is there a simulation failure when we are generating and running the Agilex ™ 5 FPGA Example Design 6x10.3125G PMA Direct (System PLL Clocking) with Custom Cadence or 8x10.3125G PMA Direct (System PLL Clocking) with Custom Cadence?
Description
Due to a problem in the generated example design for 6x10.3125G PMA Direct (System PLL Clocking) with Custom Cadence and 8x10.3125G PMA Direct (System PLL Clocking) with Custom Cadence in Quartus® Prime Pro Edition software version 25.3.1, user will encounter failed simulation result.
Resolution
For a workaround, upon successfully generated example design, you need to follow the steps accordingly to resolve this problem.
  • Step 1: you are required to go to the generated design example folder, which is: intel_directphy_gts_0_example_design/example_design/rtl_folder
  • Step 2: Open the file top.sv, then make the modification to the reset_sequencer module, sss1 at line 542. Update the o_pma_cu_clk[0] --> o_pma_cu_clk [1:0]
  • Step 3: Modify the pma_cu_clk[0] in line number 787 in the same file (top.sv) shown below from:
i_pma_cu_clk(pma_cu_clk[0]) --> i_pma_cu_clk(pma_cu_clk[1:0])
  • Step 4: Rerun the compilation and simulation. The example design will be able to pass simulation.
The problem has been fixed starting with Quartus® Prime Pro Edition software version 26.1
Updated 3 months ago
Version 5.0
