Knowledge Base Article
Why is there a mismatch on the write and read data between the AXI bus interface and the Intel® Stratix® 10 MX HBM2 simulation model messages during simulation?
Description
The mismatch occurs because the write data from the AXI bus interface goes into the Intel® Stratix® 10 MX HBM2 IP's soft adapter and through the Universal Interface Block Subsystem before it reaches the Intel® Stratix® 10 MX HBM2 memory model.
Resolution
The "write data" bus value reported in the HBM2 memory model has been modified due to the data bus inversion (DBI).
Updated 2 months ago
Version 2.0
