Knowledge Base Article
Why is there a mismatch in the MSI-X Table and Pending Bit Array (PBA) Offsets between the IP Parameter values and offset values observed on hardware for the L-tile and H-tile Avalon® Memory-mapped Intel® FPGA IP for PCI Express*?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 21.4 or earlier, the MSI-X Table offset, and Pending bit array (PBA) offset parameters set in the IP Parameter editor do not reflect the actual vector table offsets seen in the hardware.
For example, a Table Offset of 0x003FFC00 set in the IP Parameter editor will be reported as 0x01FFE000 in hardware, and a PBA offset set to 0x03FFE00 in the IP Parameter editor will be reported as 0x1FFF000 on hardware.
Resolution
To workaround this problem, set the MSI-X IP parameters in the IP Parameter editor according to the following guidelines:
  • The Table Offset field in the IP Parameter editor sets bits [31:3] of the desired Table offset
  • The Table BAR Indicator field in the IP Parameter editor sets the lower three bits [2:0] of the table offset
  • The Pending Bit Array (PBA) field in the IP Parameter editor sets bits [31:3] of the PBA offset in hardware.
  • The PBA BAR indicator in the IP Parameter editor sets the lower three bits [2:0] of the PBA offset in hardware.
For example, if you want the Table offset to be 0x003F_FC00, set the Table Offset parameter to 0x0007_FF80 (Table Offset [31:3]) and the Table BAR Indicator parameter to 0x0 (Table Offset [2:0]).
This problem will be fixed in a future version of the Quartus® Prime Pro Edition Software.
Related Articles
https://www.intel.com/content/www/us/en/support/programmable/articles/000076874.html
Updated 2 months ago
Version 2.0
