Knowledge Base Article
Why is there a fitter failure when we are migrating x6 or x8 bonding design from 25.3 to 25.3.1?
Description
Due to an improvement in Quartus® Prime Pro Edition software version 25.3.1, there is a change in the bonding placement for Agilex™ 5 GTS PMA/FEC Direct PHY IP. Following diagram shows the difference in the bonding placement between Agilex™ 5 GTS PMA/FEC Direct PHY IP in the Quartus Prime Pro Edition software version 25.3 and 25.3.1.
Resolution
For a workaround, for users that have designed their boards using the bonded port ordering in 25.3 or previous and do not want to change their physical pins or redesign, users can reassign their tx parallel data accordingly in RTL accordingly.
Bank
Mapping in 25.3
Current Mapping in 25.3.1 & Workaround for 25.3
x6 Bonding
Bank 1C/4C
CH3
tx_parallel_data [319:240]
CH5
tx_parallel_data [479:400]  --> Rearrange to tx_parallel_data [319:240]
CH2
tx_parallel_data [239:160]
CH4
tx_parallel_data [399:320]  --> Rearrange to tx_parallel_data [239:160]
CH1
tx_parallel_data [159:80]
CH3
tx_parallel_data [319:240] --> Rearrange to tx_parallel_data [159:80]
CH0
tx_parallel_data [79:0]
CH2
tx_parallel_data [239:160] --> Rearrange to tx_parallel_data [79:0]
Bank 1B/4B
CH5
CH1
tx_parallel_data [159:80] --> Rearrange to tx_parallel_data [479:400]
CH4
CH0
tx_parallel_data [79:0] --> Rearrange to tx_parallel_data [399:320]
 Mapping in 25.3
x8 Bonding
Bank 1B/4B
CH3
CH7
tx_parallel_data [639:560]  -->
CH2
CH6
tx_parallel_data [559:480]  -->
CH1
CH5
CH0
CH4
Bank 1A/4A
CH7
CH3
Rearrange to tx_parallel_data [639:560]
CH6
CH2
Rearrange to tx_parallel_data [559:480]
CH5
CH1
CH4
CH0
Updated 8 months ago
Version 6.0
