Knowledge Base Article
Why is the unexpected Assertion or Toggling of the "rx_ready" port on the FGT transceiver of the F-Tile PMA/FEC Direct PHY FPGA IP observed in the Quartus® Prime Pro edition software version 24.3.1?
Description
The rx_ready port on the FGT transceiver of the F-Tile PMA/FEC Direct PHY FPGA IP, when the Adaptation Mode is set to “Manual”, may assert or toggle unexpectedly under the following conditions:
  1. Invalid data on the RX pins from the link partner
  2. Unconnected RX pins
  3. During link bring-up
Resolution
When using the FGT transceiver of the F-Tile PMA/FEC Direct PHY FPGA IP with Adaptation mode set to "Manual", be aware of the potential behavior of the "rx_ready" port. If the "rx_ready" port asserts and then deasserts, your protocol logic must properly return to its initial state and wait for the next assertion of "rx_ready" to process data on the "rx_parallel_data" bus again.
Updated 3 months ago
Version 2.0
