Knowledge Base Article
Why is the Transceiver Toolkit not visible when using F-Tile PMA/FEC Direct PHY Multirate Intel® FPGA IP?
Description
Currently, Transceiver Toolkit is not supported for F-Tile PMA/FEC Direct PHY Multirate Intel Agilex® 7 FPGA IP in the Intel® Quartus® Prime Pro Edition Software version 22.3 and earlier.
Resolution
This feature has been supported by the Intel® Quartus® Prime Pro Edition Software 23.1. To work around this problem, you can run Transceiver Toolkit by using F-Tile PMA/FEC Direct PHY Intel® FPGA IP.
Updated 2 months ago
Version 2.0
