Knowledge Base Article
Why is the timestamp value of the Stratix® 10 FPGA Hard IP for PCI Express* IP Link Inspector overestimated?
Description
Due to a problem in the Stratix® 10 FPGA Hard IP for PCI Express* Link Inspector, you may observe that the timestamp value is larger than the actual time.
For example, when using the Stratix® 10 FPGA Hard IP for PCI Express* coreclkout at 125MHz, the timestamp value will show approximately 20% over the estimated value (12ms compared to the actual 10ms).
This is due to a discrepancy between the user-defined coreclkout at 125MHz or 250MHz, and the 100MHz clock always used by Link Inspector.
Resolution
To work around this problem, apply a multiplication factor on the timestamp value as shown below.
When using a 125MHz coreclkout, multiply the timestamp value by a multiplication factor of 0.8 (100MHz / 125MHz).
When using a 250MHz coreclkout, multiply the timestamp value by a multiplication factor of 0.4  (100MHz / 250MHz).
This problem is scheduled to be fixed in a future release of the Quartus® Prime Pro Edition Software.
Updated 3 months ago
Version 2.0
