Knowledge Base Article
Why is the read data misaligned when using the ALTASMI_PARALLEL megafunction?
Description
The dataout[] port from the ALTASMI_PARALLEL megafunction will be misaligned when reading from EPCQ devices if the number of dummy cycles set in the EPCQ non-volatile configuration register (NVCR) does not match the value expected by the ALTASMI_PARALLEL megafunction.
Resolution
To ensure that the correct number of dummy cycles is used by the ALTASMI_PARALLEL megafunction, use the Read device dummy clock port on the ALTASMI_PARALLEL megafunction. For more information on this feature refer to the Active Serial Memory Interface (ALTASMI_PARALLEL) Megafunction User Guide (PDF).
Updated 2 months ago
Version 2.0
