Knowledge Base Article
Why is the phase shift resolution for the ALTPLL megafunction in RTL simulation different than the expected value?
Description
When performing RTL simulation of the ALTPLL megafuction, the phase shift step resolution may be different than the expected value when the PLL type is set to "AUTO" by turning on the Select the PLL type automatically option in the ALTPLL MegaWizard® Plug-In Manager. In this case, the simulation model may choose a different VCO frequency than the ALTPLL megafunction, and the phase-step is incorrect.
This problem does not effect gate-level simulation using the ALTPLL megafunction.
The correct phase shift step resolution can be determined by calculation. Please refer to:  Phase-Locked Loop (ALTPLL) Megafunction User Guide (PDF), in the Dynamic Phase Reconfiguration Chapter. From this User Guide, the finest phase shift step is 1/8th of the PLL's VCO frequency.
Resolution
To work around this problem, turn on the Create output file(s) using \'Advanced\' PLL parameters option on the Inputs/Lock page of the ALTPLL MegaWizard Plug-In Manager.
Related Articles
Updated 1 month ago
Version 2.0
