Knowledge Base Article
Why is the o_rx_pcs_ready of the F-Tile Ethernet FPGA IP not asserted in PAM4 cases with PMA REFCLK set as 312.5MHz variants fail with PCS ready low when VSR assignment is enabled in the design QSF?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 23.1, the o_rx_pcs_ready of the F-Tile Ethernet IP is not asserted in PAM4 cases with PMA REFCLK set as 312.5MHz variants fail with PCS ready low when VSR assignment is enabled in the design QSF.
Resolution
To work around this problem, disable the VSR assignment in the design QSF.
This problem is scheduled to be fixed in a future release of the Quartus® Prime Pro Edition Software.
Updated 2 months ago
Version 2.0
