Knowledge Base Article
Why is the O-RAN FPGA IP reset polarity is inverted in platform designer?
Description
Due to a problem in the O-RAN FPGA IP version 1.9.1 and earlier, the input reset signal maps to incorrect polarity when instantiated in Platform Designer. As the input reset to the O-RAN FPGA IP is active low, Platform Designer should automatically map the signal type to reset_n instead of type reset.
Resolution
To work around this problem, perform the following steps:
1). Open the oran_hw.tcl file available at <quartus_instalation_dir>/ip/altera_cloud/oran/src/.
2). Find and replace the following lines of code:
a). From add_interface_port rst_tx_n rst_tx_n reset INPUT 1
To add_interface_port rst_tx_n rst_tx_n reset_n INPUT 1.
b). From add_interface_port rst_rx_n rst_rx_n reset INPUT 1
To add_interface_port rst_rx_n rst_rx_n reset_n INPUT 1
c). From add_interface_port rst_csr_n rst_csr_n reset INPUT 1
To add_interface_port rst_csr_n rst_csr_n reset_n INPUT 1
